The fronts I have the 2000 S10 4wd and they fit but I fitting at the hard line is a different size. Looks like the syclone has a 3an and the s10 has 4an? Is that what you found ? If so what adapter did you use ?Front or back?
On the front I used the 98 and up blazer hoses, with an adapter to adapt, the brake line up 1 size. On the back I just used the factory line between the body and the rear
IIRC it's 3/16" and 1/4" inverted flare fittings. You should be able to go to NAPA or another auto parts store and buy them. I have a kit of all types of conversion fittings and I just replace them as I use themThe fronts I have the 2000 S10 4wd and they fit but I fitting at the hard line is a different size. Looks like the syclone has a 3an and the s10 has 4an? Is that what you found ? If so what adapter did you use ?
Thanks I’ll check it outI think the NAPA number is BK 6413305 if that isn't correct, its 1 size off.
