I know this radio is popular with syty's so i thought i'd post what i found from another site.
This basically gives you an Aux. In to the radio.
Has anyone done this?
Here's the post to give it credit.
The CDA-D852 has to be tricked into allowing an Aux. input.
First you need to buy a KCA-121B adapter.
Get a mini-toggle switch from Radio Shack
Go into menu and select "Mute Off" (press the power button for (3) seconds and hit #2 to turn it off.)
Hook up one side of toggle to ground
The other to the Pink/Black wire
With the switch ON, it will play Aux input
With the switch OFF, it will play from the HeadUnit itself.
