Dana R. Hess
Hello members, l am in need of the plastic tube between the air filter box and the turbo. If you have one please contact me at hessmd@att.net. Thank-you, Dana Hess.
Hi Dana...did you ever find the tube you were looking for? I'm looking for one...wondering where you found yours?Hello members, l am in need of the plastic tube between the air filter box and the turbo. If you have one please contact me at hessmd@att.net. Thank-you, Dana Hess.
My Typhoon is stock...battery and overflow tank in stock location.You may see those on eBay once in a while, but most are pretty brittle with age and have deteriorated. Sportmachines probably has some as well, but I'm guessing price is pretty hefty.
Is your truck stock? Battery and overflow tank in stock location?
I have one of those tubes. The ends about 1 inch back are missing. I would guess that they probably were broken off by overtightening the hose clamps. The couples work and tighten down just fine. The only other issue is the nipple has been broken out of the tube and was reattached with silicone. I could reattach it using my plastic welder. It is certainly not brittle and palling apart.
I have my original tube, but each end has cracked....Have you seen anyone install an adapter to the tube to extend each end for proper fit?I have one of those tubes. The ends about 1 inch back are missing. I would guess that they probably were broken off by overtightening the hose clamps. The couples work and tighten down just fine. The only other issue is the nipple has been broken out of the tube and was reattached with silicone. I could reattach it using my plastic welder. It is certainly not brittle and palling apart.
Thank you so much!Some guys will have something like this made at a local machine shop.
I didn't need to add anything to it was plenty long enough to attach without any problems. But the suggestion by gmemony2 is a good one. Something could be fabbed in metal or something in plastic if need be.I have my original tube, but each end has cracked....Have you seen anyone install an adapter to the tube to extend each end for proper fit?
Excellent feedback, PhilI didn't need to add anything to it was plenty long enough to attach without any problems. But the suggestion by gmemony2 is a good one. Something could be fabbed in metal or something in plastic if need be.
