Dash lights not working
fivetodrive
CRISPY
I don't seem to have power at the fuse. So I guess I'll have to pull down the fuse box... Any other ideas?
I already switched out the switch and dimmer...
I need a dang plotter to print out the wiring diagrams...
Sy644
DEAF Syclone
Be careful! My Syclone harness got burnt real bad by the foglight wiring. Check it!
same dash out with fuse good. Went searching for it and gave up and drove it for a while until big smoke coming out of under the dash. All wiring was melt. So I searched “why” it happened and found the fog light housing touch wiring and it shorten. Almost fire it down.
Sy644
DEAF Syclone
Hell yeah I bet that is foglight wiring. It was so scared so I added fuses on foglight wiring under the dash.
len and housing bolt together and wiring touch the housing which is metal.
Hope you find that wiring and fix it ASAP! LED foglight is better!
Sy644
DEAF Syclone
Master switch in rear of my Syclone saved it from burn down to ground. I turned it off quick after saw a lot of smoke and thick coming out of the dash.
DaveP's Ghost
Do the tail lights work? The TAIL fuse feeds the dimmer switch which then goes to INST LPS fuse then to the panel lights. TAIL also feeds the fog relay. The fog lights power comes from HRN DME.
fivetodrive
CRISPY
Ironically I tested the brake lights and one went out. I have tail lights and now dash lights all the time. I have power at the horn/dm fuse and power on the 3 wires on the left when the lights are on...
fivetodrive
CRISPY
I can’t seem to find the connector on the wiring diagram. Does anyone know the connector number for the fog light switch?
wildphil
I Love My Ty's
Is the connector broken on yours? I can't see the picture well enough to tell. I may have a fog lamp switch if you need one.
Or are you just looking for wiring diagram info?
DaveP's Ghost
The fog light wiring is stand-alone. It is not incorporated into the Inst Panel harness. It is tie-wrapped alongside the IP harness. It begins with two wires (lt green and purple, or sometimes black/wht in a Sy) coming into the cab below the brake booster. Then 3 wires tap into the fuse box taps, then the break-out for the relay (grey conduit) then it goes to the connector for the switch. When everything is new and stock (not dorked with), the connector for the switch is screwed to the bottom of the recess that the headlight switch panel covers. It is about 3" back from the face of the bezel.
