Destroyed Terminator from a roll
Neelsonwheels
Re: Destroyed Terminator from a roll
I am not sure about your estimate on the 1/4 time with the pte 67. David the previous owner of my truck went 11.3 with a PT61mm at 25 pound of boost. I would think the 67 should be closer to high 10's. You running Methanol? Then again you are in much higher altitude correct? Good luck. :tup:
nothingsacred
Yeah like I said, I had blanket information at best. In other words, I can name some parts you have and that's about it. Admit this though, on that little RX7, those tires look pretty big in the back:lol: And like I said, I haven't seen the car in a while and have never seen it up close or with the hood up.
Do you usually go to PMI or Bandimere?
PMI never tried bandi long way for 1 pass
TYTILIDIE
METH HEAD
The SYTY guys in the 10's with that turbo dropped an ass load of weight, were Syclone's and at sea level. When I ran my 12.2 that was at 22psi. I don't think I'll make low 11's with this thing, not up here anyway and not considering I am not willing to strip the truck down, ditch my stereo, stuff like that. I like being able to drive my truck when I want and be comfortable.
TYTILIDIE
METH HEAD
Well, if I go out enough and to the right places, I can have video for every race. And yes, even the losses:tup:
It's just a six
Super Member
You could even race some 10 second rides on the street, alot of times they cannot hook-up & will even crash.:2cents:
Neelsonwheels
I take it that the issue you had with the oil exiting the tail pipe was turbo seals?
I assume all is well with the engine then other than the high crankcase pressue?
TYTILIDIE
METH HEAD
No idea yet, I just got my leak down tester yesterday, just need some time to do some testing.
IpHoOnDyou
Your info is wrong. I went 10.83 in '09 on a 100% stock LS1 with a 150 shot. Never seen more nitrous then that. Its now a built engine, cam, heads,more compression, headers, blah blah blah.. Only on a 100shot so far should be a bit quicker then stock with the 150hit. yes I will probably go up to a 250 and shoot for 9's if the stock 4l60e and stock rear diff hold up. 10.5 ET streets are not huge slicks.
http://www.youtube.com/watch?v=P24bSZzUOZg
The Charger you raced ran a best of 12.8 @ 109 on the motor...low 13's on the street?
That 4L60 of yours will blow for sure! With as much power as your putting down, it will let go sooner than later
MIXEDBREED
Wow sounds like I'm on rx7club again everything you said is incorrect...
Sure it is, cause it's not like I have helped build 2 different rx7's with ls2 engines or anthing:roll:
Have you seen a v8 swap rx7 try to get traction with reg street tires, dont you currently own one? Guess what it's not gonna happen till they get rolling a ways. Hell even the stock turbo ones will spin the street tires from a dig. Are you trying to say that a rx7 with a v8 swap is not nose heavy? Maybe you should go put it on the scales and see for yourself. :tup:
Maybe I should clarify for you that I said reg street tires not dr's or et street cheater slicks. There is a huge difference there.
Oh not to mention i have raced several v8 rx7's and even v8 swapped 240 sx's. Some turbo v8's and others nitrous. All builds are different but you can see a easy pattern within them though.
420
Broke Ass Racing
This thread is awesome. Gave me the motivation to go wrench on my truck again. Thanks to all involved :)
