wildphil
I Love My Ty's
I can't answer about installing stock mounts while the engine is still in the truck. I have only removed stockers and gone back with 2 types of solid mounts. I am sure what Dave has posted is what needs to be done. He has been working on these trucks for many years and has done about any work on them that can be done. I have placed new rubber mounts when installing a engine in a truck but will never use them again.
I know deciding what mounts to go with is hard. With Dave having issues with the JSM mounts that is not good news to hear about a product. And I don't even know if they are still available to be purchased. Sportsmachines sells a set of solid mounts and they are sold with the required replacement frame pads. I know nothing about these at all I have never heard reports about their use. Then we have the JTR option. To me they look like they could be a good viable option for the issue. Rubber to help cut down on vibration and the design looks like it will continue to hold even if the rubber tears for any reason. They will take a good bit of work to install.
I would never install a stock type mount unless I had the engine strapped down with a chain. But I don't like the looks of using a chain to hold the engine, so that is not likely to happen.
I believe for me I would still try the JSM mount on driver side with stock on the other. I may have the area beefed up at the weld. And also check to make sure there is no binding. I did not have this issue on the one that I installed. Actually the one that I used fit exactly like it needed to. And I thought pretty easy to install. But we all know parts are not always how they need to be and they don't always install very easily at all.
