cosbysweater
So ever since i can remember ive always wanted a Typhoon, i rember growing up and one of my teachers had one and i thought it was just the coolest car ever. However as life goes on you get other project cars and kinda just go with the flow and forget about your dream cars. Well a few weeks ago my dad tells me, hey my friend has a typhoon that hasnt moved since 2006 and is looking to sell it. I had been looking at a few mercedes wagons to buy and when this popped up i jumped on it. This car is a survivor for sure with 159,000 unmodified miles, its been under a car cover in a dry garage since it was parked. It needs basically all the suspension bushings and just to be gone through. So i used his hoist to drain the fuel from the tank, i had tried to power the pump up and got nothing, so go figure it had a dead pump. Ran and got a delphi pump and drained the varnished fuel from the system and installed the new pump. I threw some unleaded sunoco 104 in the tank and took the valve out of the fuel rail and flushed the rail out. I also changed the oil and installed a new battery. All the fluids had been changed prior to being parked which was nice. I had no fuel smell in the oil at all and no condensation either. I turned the key and the thing fired right up just like it had been running the day before! I threw some air in the old tires and let it get up to temp and drove it 30 miles home with 0 issues. When i first started driving it there was quite a bit of blue smoke out the exhaust for about the first 3 miles, mostly when pulling away from a stop, im figuring som oil has leaked past the valve stem and turbo seals from being parked for so long. By the time i got home there was 0 smoke and it was idling very very nicely. So im going to be going through the car and cataloging my adventure here. there is surface rust on the frame but nothing concerning, im going to go through and clean and coat as much as i can within reason. plan is to get the air suspension working again as it has been disconnected. but even the cruise control works on this thing!
and back home
i removed the wheels to get the tires pulled off and get them redone, they had been chrome plated and all of that was flaking off so they look ratty. luckily there was a set of zr1 wheels sitting around so i threw them on as rollers for now so i can get the stock wheels redone.
the lower intercooler radiator was leaking pretty bad from the center core so i contacted sportmachines and have a replacement lined up from them. im trying to keep it as original as possible.
the upper ic brick had a bad over flow nipple so that was fixed as well and i reinstalled it
thats all i have as of now, just placed a big order to redo all the suspension on the car and get it driving good. Ill update when more developments happen!
and back home
