ls1typhoon
My LS1 Typhoon came with a non working oil pressure gauge. The sensor is already installed on the LS1 block, but nothing connected to it. I have not found the connector/wiring from the gauge that should plug into the sensor. I'm pretty sure it is just missing or mistakenly cut. I can buy a new connector from my local parts store, but I cannot find the wiring from the gauge... Short of of removing the instrument cluster just so I can trace the wiring - does anyone know where the wiring bundle is routed? I can't see or feel behind the the cluster to tell. I know the Typhoon service manual shows it goes to connector C201 pin D. I have not found that connector...
Can anyone tell me where that connector is located or point me in the right direction to resolve this problem?
Btw, my Typhoon has an off the shelf wiring harness for the conversion.
Thanks in advance,
Eddy
Thanks in advance,
Eddy
