02 MV - Too Lean?
AXXE
I have the Ultimate, stock turbo, Walbro 255 HP and intake and exhaust mods. At T2-18 WOT O2 is reading like 895-915, with no knock retard. Is this too lean?
AXXE
Thanks. I am running a 55lbs base fuel pressure. I have a new filter and the HP Walbro. Is that normal? I am starting to wonder if this engine has some internal mods. It idles kinda rough.
<font size=-1>[ This Message was edited by: axxe on 2002-03-11 19:52 ]</font>
AXXE
When it was cold out I ran T3-17 with 1-2 degrees of knock with 94 octane. I am not the original owner and am starting to wonder if there are some internal mods. It doesnt look like the engine has ever been out. Still has all those factory clamps on all the vacuum lines. I need to get to the track with the new mods. That will answer my questions.
Tooky
Serious about performance
Dear Sir, please post up when you come back to the track, I am anxiously following the results of your Sy as it seems to be a phenom of some sort!
AXXE
Using Datamaster, it runs best when it is cold on T2-18. There is a wastegate problem or something because it only makes 18psi when it is cold out. I havent made any rod adjustments yet. I wish I knew who the original owner was. I am starting to wonder about this thing. I should be at Englishtown Friday night if the weather holds.
E-Rue
you should check your timing. sounds like your truck might be a few degrees retarted. if not, then id say your truck is really special.
e
AXXE
I have not checked the timing, but it ran 12.9 with the stock chip, manually shifting it. After a night at the track it should clear things up.
