13 gallon sy conversion project
cloneman315
I am going to try and document this project,I am going to pull the stock 20 gallon out and swap in a 13 gallon tank. I am also going to make braided linesor parker push lock from the sender to the break out lines by the transfer case,I will list part numbers and pics etc as I get them,
This pic is the factory lines that go from the fittings by the transfer case to the fuel filter and tank.
The 13 gallon sender on the right and the 20 on the left.The lines seem to be the same.
The 13 gallon on the left is a bit shorter than the 20
The one on the left was from my sock for the 340 pump,the right is for a stocker type or 255
SYCLONE#1531
'MOFOFAST
Re: 13 gallon sy conversion project
cool! Ive gotta put my 13 gallon tank in. please post the part#s when you get them..
Would you happen to have another sock for the 340 pump? My old strainer is the same as your 340 piece and I am looking for a new sock with the same coupling and cant seem to find one.
Tyclone
excuse the stupid question
what are the 13 gallon tanks normally found?
cloneman315
I have the an parts coming this week and will post pics and numbers,here I bought a 3 pin packard plug I am doing my ground,sender,boost a pump wire all in one plug for easy tank removal.
cloneman315
Few more pics,Converting stock metric to an
Following parts numbers
-6 house bulk
2 earls ear-9894dbherl
2 earls ear-9894dbjerl
2 sum 220606 -6 45 deg
2 sum 220687 -6 90 deg
2 sum 220690 -6 straight
chelo
filthy sy
I might be the only member here that would actually like a bigger tank. Great project by the way.
cloneman315
thts what I am thinking, Just need to wait and see how it works when I get the tank back from cleaning.
blackty
Brian, any updates? Got my fittings from anplumbing, Earl's online store, saved over $2. per fitting over Summit. Going the compression fitting route with 3/8" copper for lines(endorsed by Hood). Fittings rated for 100psi. I'm going to slide 3/8" id insulation over the lines to eliminate any vibrations. Even considering a full port ball valve to be able to shut off gas supply as a theft deterent...Jim
cloneman315
I will be finishing this project over the next week or so,I have a 13 gallon tank on the way and will post pics etc.
