93's were made from the leftovers.......
Didnt make any difference compared to what ? you forgot to paste the rest of whatever you copied , lolThe 1985 - 1995 LB 4 TBI heads were used on Syclones and Typhoons. Those heads were the "swirl port" heads to increase low end torque for towing. They have a "ski-jump" in the intake ports and are out of breath by 4,000 RPM. . However, on a turbocharged engine, the swirl ports did not make any difference. The 1992-1995 L35 CPI heads are not swirl port design and are better to use on any 4.3L engine including a Syclone or Typhoon. I have heard that L35 heads will increase the HP by 20 - 30 HP at 5,500 RPM on a turbocharged engine.but that may be with a cam change. I installed unported 1993 L35 heads on my 1991 Chevrolet S10 Blazer 4x4 and it made a big difference in HP production above 4,500 RM using a Comp Cams .500"-.500" lift camshaft, ovate valve springs, and LS1 - LS7 roller tappets. . .
So '92 typhoons say what on the intakes again ? :lol:
Fuel rail was different, but not anything performance related
There all Junk Dont By anyBut then again your talking to a guy that has 5.
Endless repair nightmare. I bought 5 sets of jackstands.
Make sure you but a set soon as you buy a syty. And lots of tools. And clean out your garage.
Because its going to sit in there for awhile.
The 1985 - 1995 LB 4 TBI heads were used on Syclones and Typhoons. Those heads were the "swirl port" heads to increase low end torque for towing. They have a "ski-jump" in the intake ports and are out of breath by 4,000 RPM. . However, on a turbocharged engine, the swirl ports did not make any difference. The 1992-1995 L35 CPI heads are not swirl port design and are better to use on any 4.3L engine including a Syclone or Typhoon. I have heard that L35 heads will increase the HP by 20 - 30 HP at 5,500 RPM on a turbocharged engine.but that may be with a cam change. I installed unported 1993 L35 CPI heads on my 1991 Chevrolet S10 Blazer 4x4 TBI and it made a big difference in HP production above 4,700 RPM with a Comp Cams .500"-.500" lift camshaft, Comp Cams ovate valve springs, and GM LS1 - LS7 roller tappets. . .
93's were made from the leftovers.......thats why the interiors are the stock slt jimmy.....
30 hp @ 5,500 rpm? My truck stops pulling at 4,800 RPM.I guess you would also need a Chip tune change to go with those parts. For only a 30 hp gain, it would be better to just up the boost and retune is what I'm thinking. I would also add Alky injection to be safe.
Were you using the comp 918 beehive springs that are for LS-1s? Are you also saying that LS-1 roller lifters are compatible with these engines? I have a ton of LS-1 parts, but I will never take this engine apart to mod it, it runs pretty well in stock trim.
