2000+ with turbo 4.3?
BradW
Would it be possible to get a 2000 or so S-10 or Sonoma with a 4.3L and then just swap out the motor with a built 4.3L turbo (syty) motor? Then also go to a 350 trans and a F.A.S.T computer system. Would all this bolt right in other than the trans? Or is this something that would not work?
Thanks,
Brad
BradW
a little more detail than that would be great.
Are the motors the same about the same? Has it been done already? Will a turbo setup fit with having to cut up the front end and customize things?
smeagol
Motor will bolt in
newer engines have accessories mounted differently, so if you reused the newer style accessories, you may have to do some tweaking to syty crossover pipes (in front, below crank pulley) to make it clear accessories.
The computer, overflow bottle & battery are kinda jammed in on the passenger side. Relocate/remove those to help with turbo inlet issues.
I'm sure there are some fabrication/creativity issues to be done, but otherwise it wouldn't be *that* bad a deal. www.tobefast.com has a 2wd Syty powered truck that has gone fast. It was at the Syty nats, making some fast passes. They went full out race though, removed AC, syty style accessories, FAST, Powerglide. Intercooler *may* present some issues, nothing that can't be dealt with though.
Building off the newer engine/computer is NOT a good idea if you are looking to make some big hp though. Block *probably* is weaker, heads & cam are great, but the intake/injectors will present issues.
You could make a very fast truck this route, but on radials it might not get the best traction.
BradW
I was more or less just checking into the possibilities. I would only use the stock setup on a newer truck as far as the accessories and everything goes. Most likely would go with a whole new motor that is built and just sell the original 4.3 that comes in the truck.
Would just need to customize the turbo components, new crossmember for the trans, new drive shaft, and other misc. things.
That sound close?
smeagol
Also, downpipe is a bit of custom deal, since I believe the frame is different in the newer / 2wd stuff.
TurboManiacal
Bill Mach is the first to market with a 4.3 turbo kit for 96-01 trucks. Give him a call his kit will be cheapest all around.
