32 valve heads
Bill Z
Re: 32 valve heads
I only have a 6 cylinder. How do I cram 32 valves in? Wonder if he makes any 24 valve 6 cylinder heads? Probably cost more than my whole engine.
gkrcr882
SyTyless......for now!
Re: 32 valve heads
Wow, thats pretty cool. It would be nice if heads could be made for the 90* V6, but it would probably cost a fortune:roll:
90stangGT
Cobra member
Re: 32 valve heads
I have heard of this being done, but have heard a couple bad things about it, ie too much pressure on the pushrods/cam?? It has been a while.
Loeryder
Re: 32 valve heads
Since they have a small block head the engineering to get a 4.3 head wouldn;t be too tough.
Just saw the front 2 cylinders off and patch it up.
Their info says they are good to go for blowers, turbo or nitrous.
Someone should send 'em an email and see, but I bet they are $$$$!
TT350
Manufacturer
Re: 32 valve heads
HotRodV6 said:
I remember reading about those from several years back, and i think they are somthing like 5 grand for a set of basic SBC heads. Crazy
If these heads are as good as they say they are
it would take at least a $5000 set of 2V to even
get close.
Look at some of the dyno #’s there’s one small block
making over 650 hp with a baby HR cam and dual plane
intake that’s insane!
If your in the market for this kind of power $6000-$7000
grand is the norm.
TurboJunk
questionable
Re: 32 valve heads
get close.
grand is the norm.
my answer to 5-6000 cylinder heads....... MORE BOOST!!! end of conversation
Re: 32 valve heads
I read about those heads 10 years ago when they came out. I haven't heard much since then.
THEMADTYPH00N
Re: 32 valve heads
Check out CamaroZ28.com theres two guys over there that have those on LT1's they are building. I think one of them is even running.
ghettosled
SYTY SUPERSTORE
Re: 32 valve heads
these guys are aboiut 2 blocks from our shop.. pass them everyday going to work... seen some of the big block heads before, but thats about it.
cdezzz
Re: 32 valve heads
Dominion Performance was the companies original name, but has changed it to the current.
THEMADTYPH00N
Re: 32 valve heads
I've never seen any # from these yet. But for that kind of $$ I'd think a set of SB 2.2 would come damn close if not the same performance.
HotRudyRod
Re: 32 valve heads
That $9,999.00 Hi Port sounds out of a dream. Wonder how hard and expensive it would be to make it run on the street with FI and some kind of forced induction.
