Re: A/C Delete ?s
Andreas said:
Alittle SOB to get the cooling exchanger out thats within the plastic/fiberglass box thats mounted on the firewall.
Yup, I ended up spliting mine in two to get mine out. Backed out the screw that held the two halves together.
If you still have the mechanical fan, that is going to have to come off as well as the upper radiator shroud. Remove the serpentine belt
AFTER you after you break the nuts loose on the fan to help hold it in place.
The one bolt that holds the AC clutch on at 4 or 5 o'clock prolly won't come out easy. All the bolts have a "flat" on the side of them so that they can be "clocked" to remove them. You will probably have to drive that last one out with a long punch. I did on my truck...
