Slyclone
Well-known member
Air is not working. Have not used it at all since owned truck. There are 2 wires attached to compressor housing. With system on, MAX AC, BI level, Does not power up. I tried to probe the area as well for 12v or any type of signal and nothing. Also traced the wire back to the rear of engine. The black is a Ground. where does the green migrate to the ECM?
Looked for what I thought was the relay and its on the pass side furthest side fire wall? 2 cubes this one is a BOSCH unit.? COuld that be bad? how do we test out. I tested the 4 wires comming in and 2 supplied 12v
