Re: A/C question
I had an interesting experience with this. I volunteer at the local JC diesel class. Next door is auto. Got to talking to the the guy who teaches AC and for a teaching "moment" he used a fancy-dancy machine to convert the truck. I thought it was SnapOn but haven't found it in a short search.
Very interesting. It sucks out whatever R12 you have, vacuum tests the system and refills it with R134. Hoping I have my numbers correct... Anyway Went to Kragen and bought BOTH GM conversion kits. (It took one from each to convert the fill valves as I recall.) We had to fill it twice, I forget why. On the second fill it's cooling fantastic but the compressor is cycling. Teacher says it a pressure issue. Well it turns out that our pressure switch is adjustable. (At least mine is) Pull the connector and there is a screw down inside. I seem to recall I backed it off 2 turns. (Could be wrong here.) After that worked like a champ.
I must have a small leak somewhere because it eventually bled down. I was unable to go back, school ended.
Anyhow, FYI, our system is an A/C Accumulator system as opposed to a Receiver-Dryer system.
"An A/C accumulator is used in cars that have an orifice tube and not a thermal expansion valve. An orifice tube is found in automobiles created by Ford or GM."
For some reason it seems to me with our system the accumulator doesn't need to be changed but if we had a receiver-dryer system the dryer would have to be changed. Someone should check that.
This is just about the end of my A/C knowledge/experience..:rotf: It was fun to watch the kids learn, I learned almost all the above, and I did have A/C for a few weeks.
HTH
