A Little Help
TYHOGG
Can someone please give me a the number off their stock chip in a 93 typhoon. I need to order one from gmc and they need the memcal or chip number.
100in6
100in6
Re: A Little Help
i'm sure someone will help you, but if not i will ask my son to pull the one out of his 93 ty and get the number. but he is working all weekend and i'm sure won't have time till next week. let me know if someone doesn't help you before then
les
SeattleSy#1255
Category 5 Conservative
Re: A Little Help
is this what you want? from sytyauthority!
MEMCAL ScanID Delco ID GM Part #
3051 AXXA 3086 16163085
3961 AYBM 4053 16164052
3971 AYBN 4175 16164174
8581 AWXJ 9137 16159136
831 BBZA 1576 16181575
841 BBZB 1580 16181579
ECM old GM #1227749
new GM #16198263
TYHOGG
Re: A Little Help
Seattlesy; yes thank you that is exactly what i'm looking for. I tried to call GMC to order one, but they need a certain number cause even off the vin there are about 12 variations (at least thats what i was told).
Thank you.
TYHOGG
Re: A Little Help
Another problem. Only at idle i get my "check engine" light on. It will only make 5lbs of boost. Once i start moving about a block it goes off and it will make 15,16,17,etc. Any one have an idea on whats going on. I figure it has to be either the map sensor or ultimate. Any input would be awesome.
Thanks guys.
