AEM DFI
canadian
sy in progress
http://www.aempower.com/ems.htm
anybody ever seen this in person? grabbed some information off of another list, but don't know much about it:
"I have been spending some time working with one on a
non ford application and am thoroughly impressed.
Things like wide band feedback, automapping, internal
high speed logging and a killer boost control system
are only a couple things that I have found to be what
I need in a controller. You can find out more about it
at: http://www.aempower.com/ems.htm
I don't have any prices yet, but I will probably have
them available on my website as soon as the unit is
completed. "
"Want to monitor EGT, and have the controller adjust
fuel based on EGT at say WOT and full boost? Want to
run secondary injectors? Would you like to have your
turbo boost level controlled dependent on vehicle
speed? (for example 10psi at 10mph and ramp up to
20psi at 70MPH). Want to run two wide bands (or
regular O2s) and have each bank trimmed seperately?
Want to log data at a sampling rate of 250Hz and take
a derivativetive of engine speed to see how a change
has modified your torque curve? All of this and more
is possible with this controller.
Is it overkill for some people? possibly, but it's not
something that most people will be able to grow out of
soon.
It does have a couple drawbacks - one not being able
to directly drive low impedance injectors, but you can
go pretty fast on high impedance injectors, especially
if you are using additional injectors. I'm using low
impedence in my car (as are my dad and Bob) and I am
only running about 65% DC at 9.9s and 140+ MPH. "
