Yes, using the stock turbo, it says to re-clock the compressor housing and you cant because there is a notch in it and it only goes one way. Do you have the same kit, and what turbo do you have?
also once you reclock the stock turbo.. if your still using the stock wastegate setup you'll have to make a bracket to house the wastegate or contact "mikerenz" he makes the bracket needed for what im talking about
