agressive advance (thinking loud)
nightdiver
I was just thinking how much more hp would we get from an engine ...lets say ....33* advanced under boost.
the NA engines goes up to 38* (SB) so a well prepared engine with hi flow headers, big turbine(less back pressure) , methanol injection and race gas could handle it
Im not going to do that ...just thinking loud
Jer
Don't taze me bro!
Re: agressive advance (thinking loud)
Best bet is to run as much boost as your turbo can run before it begins running inefficient and then dial in the timing until just before you get knock (ie, seeing knock and then backing off). The level you want to run up to that mark is up to you. Some choose to back off a decent amount to be on the safe side and some prefer more to run on the edge by going a tad below knock. Bottom line is you'll get more power from boost than timing so the key is to add in as much boost as possible, even if it means you retard timing to do so.
BillC
Maximum engine power is developed when the peak cylinder pressure during combustion occurs at about 13 degrees A(fter)TDC. Since combustion requires a finite amount of time to reach max pressure, ignition timing must be advanced to some amount B(efore)TDC to allow max pressure to be reached at 13 deg. ATDC. Advancing timing to the point where max pressure occurs before this point actually reduces the power output, and if pushed too far can cause significant damage the engine, without even considering the increased proclivity for detonation (knock).
Since a highly-compressed air/fuel mixture burns faster than a less-compressed mixture, boosted engines require less timing advance to reach max pressure at the correct point in the cycle than naturally-aspirated engines.
Water- and methanol-injected engines use more timing advance because the injection reduces combustion temperature, which reduces the tendency to knock and the rate of combustion. Because the combustion rate is slowed down, the engine now needs more timing advance to get peak pressure back to the "magic" point.
So, the amount of advance an engine requires to make max power is dictated solely by the rate of combustion and the amount of "lead" required to make peak pressure occur at the right time. People usually back off a little from that "max power" timing value, to add a little "safety cushion" to help protect the motor from bad gas, knock, etc. But, there's a physical limit to how far you can advance timing before you blow up your motor.
nightdiver
Thats exactly what i wanted to hear/read.
Its the combination of the internals and fuel we use. Best way to see whats going on is to go on the dyno i guess.
I run 27* under boost because of the two meth injectors i use so id say thats good enough.
On a 100* day i got 74* intake temp with 22 psi.
98 oct gas and meth gives me 0* knock at 29 psi. Ive got on intention to raise the degrees...no way.
Thats what Brian told me some time ago and i do take his advise
I think you need to dyno test to see what works best, with a good datalogger going to see if you are having any minor detonation. One thing i've seen in any engine, is that it typically likes the least timing at peak torque, as it's under the most load. I can't say whether or not you can do a bit more timing. Myself - i'd probably not push a Syty with a good head past 25-27 degrees of timing at higher RPM. At max torque , 20-24 degrees. That's just a broad generalization. Push the boost higher rather than the timing. I'd run 116-118 octane for those timing numbers even.
I hope he doesnt mind posting this ( i know he doesnt :) )
