sy#2716
SyTy 4 Life
Re: Air box opinions
I have to agree with you the stock intake was not the best design in the world going over the hot radiator and having the bottle neck over the radiator.
For the most effeinct you need to pull air from the outside becasue I promise you if you route it down toward the fog light area and conapare the intake temps from the bay mounted intake you will see a good bit decreaase int IAT with the one that is pulling from the outside of the engine bay (as long as they have the same restrictive amount)
I disagree with you on adjusting the wastegate rod and having to add a better boost controller when you add an intake that will not cause a increase in boost more than the factor controller can handle. I have 2 trucks and i have run a varty of different type of intakes on them from conbra elbows to open turbo to stock intake and a custom piece i made that pulled from infront of the passanger front tire (no fender wells) near the fog light and it was the best for the same conditions compared to the others IIRC it dropped the IAT's around 15-20* lower than the intakes pulling from the engine bay(i lost all the data on my old computer and also all the datamaster logs).
The only time you will start to have to adjust the wastegate rod and having to worry about spiking and boost controll is when you get ride of your cat or with a free flowing exhaust and you start to over powering the stock wastegate.
Just my 2cents but what do I know i am just a dumb ol redneck banker from GA.
I would have to partially disagree. Yes cold air from the core area, good. Necking it down and routing it over a hot ass radiator, very bad! Just like the IC lines. Water to air IC good idea, routing the STEEL line over the hot intake, bad! And like someone else said about starving the turbo, that's why you need to tighten up your wastegate rod and also consider a better boost controller to keep from overboosting and spiking. This is one of the first things I changed on my Sy when I got it. Intake, AFPR, Walboro, wastegate adjustment. Just my $.02.
