aldl cord bad?
cameronsclone
Been using tunerpro rt for the past few months the truck has been running, now after it sat for a few weeks I can't get my aldl cable to work. non-usb aldl to serial that i bought on ebay a year ago or so, but tunerpro says it can't find the cable. Messed with the ports and what not, I guess it just has a bad connection? does tunerpro actually look for the cable when its plugged in or does it look for a pulse from the aldl connector/ecm?
willyson
trollin'
Re: aldl cord bad?
Just did this today. Didn't recognize cable at first. I turned the truck on, switched the ports around under preferences hitting apply after each one. Worked on com 5 where it had previously failed on that port.
HTH
cameronsclone
Re: aldl cord bad?
hmm I'll try that. Did you get the same message that says cable not found or functioning? I get the same thing with no cable plugged and connected to the aldl in as when its unplugged.
