Alky before the turbo...
sy1907
SYCOTIC
I was looking for some threads on this but apparently there either aren't any or my searching talents suck...
Anyways, I was having a discussion with some engine builders up here in MN, and they said they've started to do quite a bit of this. Has anyone been spraying alky before the turbo so the charged air is cooled immediately along with the compressor housing? If so, any unwanted long term effects from this? I was worried about the turbo seals holding up to the alky, but he said it hasn't been an issue. My mind was drifting towards corrosion and such. So, thoughts/experiences?
Chime in please...:popcorn:
TYTILIDIE
METH HEAD
Re: Alky before the turbo...
My guess would be that it wouldn't make a big difference. I would be concerned that you would lose out on alky to cover the greater area. No sense reinventing the wheel. But then I am no expert.
spooldup
Super Member
aquamist has had this for years. You will see an increase in boost without touching the controller. They make an insert that fits into your inlet and the center of this metal insert is threaded so you can screw a jet into it for even displacement. You need to run the jet at a certain psi....can't remeber right now so that the meth is so fine it won't hurt the turbo.
Aeroking
e.i.
thinking back to science class. I thought most liquids were uncompressible. And you'd need a lot of PSI to compress liquid.
Also compressed liquid is dense, which would move more air to the engine. however, compressed liquid is also slow moving, which would reduce the CFM to the engine.
now if the alky nozzle is spraying at ~100psi, and the CAI piping drops it to atmospheric as it reduces air temps, then you re-pressurize it by running it thourgh the turbo... do you initialize the cooling process again?
Very peculiar.
Here is a vid I made on this with the Alkycontrol kit. The methanol should atomise nicely. You want alky injection no further than 10 inches from the intake. Thats a rule of thumb I have always used. If it get any further away you might run into problems with uneven distribution into the cylinders. Also I think you would use way more than you need to running it through the turbo.
http://www.streetfire.net/video/alcohol-injection-demonstration_682178.htm
