Alky Tuning ?'s
johnboy89
I've been using my alky kit for a bit now and noticed one thing that I'm stumped on:
As soon as I get on the truck it boosts so fast that it sees some KR before the alky starts spraying. If I ease into it I'm usually fine. I'm using the snow kit and tried turning the on psi down a bit, but didn't help much. I could take some timing out down low I guess??
Thoughts?
Thanx :D
sytyguy
Moderated User
Re: Alky Tuning ?'s
F38 is the easiest to start with but F21 and F22 might need attention for fine tuning.
Ross L
Re: Alky Tuning ?'s
I always "prime" the alky pump before a WOT. Should you even *need* alky at 14 psi?
johnboy89
Re: Alky Tuning ?'s
In my case yes as I have higher than stock compression. Never did the calculations, but if I had to guess my 14 PSI is equivalent to 18 psi stock?
johnboy89
Re: Alky Tuning ?'s
Wat is your CR?
Not sure on CR, but cranking PSI is 180 PSI. I've always figured this is what was causing my KR problem. The weird thing is that I used correct dished pistons in the block? Maybe not a stock cam, block decked too much, not sure, but alky has dramatically reduced it.
cheatham2492
Re: Alky Tuning ?'s
I am guessing you have a non progressive alky kit. I would lower the turn on psi.
Yes I would agree. I turn mine on at 3-4 psi.Your tiring to get the intake air colder faster.The more the boost pressure the "Hotter the Air"
Cheatie
Windedv6
Ty n 10s
Re: Alky Tuning ?'s
yea...your cranking compression ratio is high. 125-145 psi is more normal. If you got a correct dish size, then its head chamber size and /or cam. Retarding the cam will bring it down some. I backed my Twin turbo cam down 6* and it brought my CR down about 10#. Anything over 160 # CR is going to have some tuning issues in higher boost ranges. Get a progressive alky controller and use twin nozzles.
John
