cloneman315
Re: another injector question (GT35R)
i did the voltage upgrade last night same one turbo 6 did that he told me about it.It took me 10 min ,and the injector drivers are not on the ecm b fuse they are on the ecm 1 fuse.Here is how u wire the relay ,terminal 85 runs to ground terminal 87 gets fused constant 12volts from batterey terminal 30 goes to the ecm side of the cut pinkblack wire and terminal 86 goes to the car side of the ecm cut pink black wire.
