cche
cche
To answer RichHeezee01, that tank takes up every bit of room that is in the bumper there. I just had to loosen the front bumper some and drop the tank in, I put some dampen material on the outside of the tank on the bottom and side to kepp it from making noise if it was touching anything. I also put a fill tube in it so I could put ice in it if I go to the track. My buddy works at an industrial machine shop, so we cut and bent what we needed and had another guy weld it up. I did the tank there just because it was wasted room and I didn't want a tank in the back. I am thinking about doing something like this for alky, but have to decide where I want it. The rad was simple, just had a few holes welded up and made a few brakets, but does make the truck run a little hotter if in traffic.
I have a shurflo pump,water tank, extra cche,3/4 lines, 7" fan and scoop on the lower, the tank and lines add right around 2 1/2 gallons to the whole system, but as far as iat temps go the ram air helped the most I think, by keeping temp low before boosting.
