Backfire under accelleration
Ian Turgeon
Cascading Inspiration
Warm and muggy day, My first drive after doing plugs/cap/rotar/trans cooler and trans filter .
Truck backfired after warming up, accellerating from a stop(sitting at a light), rolling into boost slowly. I'd say it only managed to grab 5-10 lbs of boost before the backfire, when I let off.
I tried to repeat later, but it didnt backfire again.
However It does hesitate a little just off idle, if I'm trying to accelerate a little faster then my normal old-man driving style. Although it isnt consistant in doing so.
nearly full tank of gas, never had a back fire under acceleration before.
Ian Turgeon
I usually do the plugs myself, but I had a hand doing them this weekend. My old man and Adam were here helping me wrench, and they took the helm on the plugs.
I know they gapped them, because I saw them doing so, but I cant verify exactly as I let them handle it.
Base FP may be on the high side ( cant tell you off hand, set it a while ago)
Fuel pump is a walbro.
I dont think the boost spiked, although I didnt look at the graph on the controller after the incident (doh)
What are the possible causes of a backfire under acceleration?
ABLITZ
Damn Yankee
Re: Backfire under accelleration
check the timing??
if you find the cause please tell.my truck just started acting up the same way after replacing the vac lines...
Ian Turgeon
I took the truck out tonight ( dont like beating it up in the florida summer heat) and played around. I couldnt manage to get it to backfire or missbehave.
It's a little sluggish off the line ( feels like the TC is soaking up power ) but i couldnt get it to break up under boost again, I did everything but boost launch it.
SyTyJedi
Jedi Council
Did you do anything to the coil? Could it maybe be cracked?
Sounds like some ignition component is cracked and allowing a spark to jump somewhere during acceleration.
Ian Turgeon
as far as the sluggishness, I kind of attribute it to the tune of the chip, I think with the different turbo and torque converter ( 20g and 2800 stall), its going to require some changes in the chip.
It looks like i have a back fire when my truck transisition to boost as well. It their and easy wasy to test a spark plug to see if its cracked? (I recently regapped them to 0.030.) During my truck truck's last layoff I did 1.6RR, so I am going to check the valve adjustment.
Nevermind, I had my MSD 2 step on accidently. The backfiring was the engine hitting the rev limiter at 2200rpm....
SeattleSy#1255
Category 5 Conservative
not to sound to basic...but i have done it on "val" mode of the ultimate on accident.
Also, what about a sticky half ass working WG...opening and shutting at radical incremements?
Ian Turgeon
Interesting comment I hadnt thought about, I changed the gain on my controller and hadnt thought about it being a possible cause.
