DubJG
I've just began tuning with code 59 and I could use a little help.
stock motor and turbo
reliability upgrades- walbro w/hotwire, afpr, 180 t-stat, taylor wires, msd cap/rotor, ur5 gap .028 maybe cant remember, vac lines
others- abs delete, cai, bat relocate to bed, egr delete, stock dp w/3" straight pipe, 36lb inj
Im using ostrich 2.0 and extreme aldl with the stock 33lb bin and TP5
I tuned the idle to what ran the smoothest which was around 13.2-13.6 afr with the timing around 33-34 which it seemed to like. After idling for a while i took a log and rev'd the motor a few times with a max of about 2600rpm. I shut the truck off and and looked over the log in tp and the csv file in excel. It is a bit rich obviously but i was having trouble determining where and how to make the changes. Then when i started it up again before i could make changes it began to hunt a bit and would not come out of it with any changes i made. I decided to try backing up and pulling back in the garage but it nearly dies when i put it in gear.
I've read lot about code59 and Im ready to learn but i think i might need a little guidance to begin with.
sidenote: when you close tp5 and it tells you "acquisition definition modified, save?" do you save or no?
TIA
TIA
