Re: blow by
I can speak from personal, expensive experience. My truck had the same blow by, and this was the cause. Think your plan for a short block is a good idea. I had very good luck with rebuilding my own block at a local machine shop. Ended up costing a lot less than buying one from someone else or from a vendor (nothing wrong with either).
From my past thread (vortec swap)
OK
melted side of #1 piston, here is my short block build costs so far
part source cost
pistons (JE extreme duty) board member - good 400
rings estimated 120
arp studs RPM 75
eagle rods Hood 350
pro gram mains RPM 230
melling select oil pump RPM 125
cometic head gasket estimated 170
gasket rebuild set RPM 110
bore .30 over machine shop 100
line hone, four bolt main modify machine shop 200
assemble (long block) machine shop 500
clearance for eagle rods machine shop 75
turn stock crank .010 machine shop 150
clean machine shop 45
balance machine shop 250
still need SFI flex plate, bearings (clevite heavy duty), and SFI balancer. Reused cam (comp 415) and timing chain (new Edlebrock). Using stock crank (after much talk and searching). Turbo was checked out by Shiver Diesel and Injector here in Tallahassee, and was given a good bill of health. Total so far is $2610. Pretty good, I think. Machine work is by a GN guy, that is as close as I can get around here.
