When i relocated my battery i took out the vacuum ball and just plugged the vacuum line. I recently bought a Greddy electronic boost controller and was wondering if i could use this vacuum line for the boost controller?
Thanks
-Mike
depends on what side of a check valve you are on. As TYTILIDIE says above you want this on the AFPR and MAP so they all agree.
I use the AFPR and MAP vacuum source. I am pretty sure that is what the directions say to do as well. I would not use that source, may or may not matter though.
