Boost Pressure
TurboTPI
TPI Tuner
How much boost does a stock Sy/Ty run. I have a Sy/Ty ecm in my car and it goes into a fuel cuttoff mode and i cant figure out why. This occurs at like 7-8 lbs of boost @ 4500 rpm. I cant beleive that they run only 7 lbs of boost. Any ideas what would cause this. Is this the rev limit?
93ty475
Re: Boost Pressure
What injectors are you running? Any ecm mods? There are a few threads stashed away in here regarding V8 749 apps...
TurboTPI
TPI Tuner
Re: Boost Pressure
I am running 32lb injectors. Yeah, im on thirdgen.org, but i just cant seem to figure it out so i figured someone on here might know the problem. How can i find old threads about v8s running the 749 ecm?
Re: Boost Pressure
4500 RPM sounds like the stock RPM fuel cutoff. On the stock chip its 4800 cutoff and drop to 4600 before goes on. (its adjustable) Boost cut off with a 2 bar map is basic 15+ psi pegged for more than 2 sec, that can be removed.
