0966Sy
Code what?
I took the Forge actuator apart last night and verified that I DO have the blue spring (14-18 psi). This leads to the question of why is my boost holding steady at around 10 psi after the spike? I am missing something? Does the Forge need some preload to function correctly?
Yes, need to tighten up the preload. A turn or 2 past the pin is generally what I've used with good results.
