BlackTyphoon213
I have done some reading around the forums but have yet to find a solid answer for my application. I'm looking into upgrading my turbo, fuel injectors, a2a intercooler, fuel pump,fuel pressure regulator, and torque converter. I have looked several times at the xcel spreed sheet, but still am not exactly certain on which turbo to use. I'm leaning towards a billet dbb pte 67, but am not exactly sure what will work best with my current mods. Which are ported vortec heads, stock intake modded to fit the vortecs, 422 comp camp, degreable hex adjust timing set, alky injection, a stock bottom end, stock manifolds, 3in down pipe and 3 in exhaust cat deleted have a 3 bar map sensor already as well. The Typhoon will end up to be a turn key driver in the summer, but I would still like to hit 11's with the right tune at the strip. I also would like to keep the A/C. Any info or suggestions would be great.
Thanks,
Drew
Thanks,
Drew
