Houseofperformance
switchhappy!!!
it´s time for an upgrade - currently i´m running mildly ported vortecs, 412 cam, bigger valves, forged internals, 4 bolt mains, a pte 44 + 3" downpipe and 50´s injectors with 15 psi boost, 2800 stall in the 4l80e.
it runs strong and flawless but i don´t think this combo brings out the full potential of the engine.
i have following parts already: large front mount a/a intercooler, a bbk throttle body, 90° upper intake plenum facing the front, edelbrock lower intake converted for efi (in the works at rpm) - i guess with this parts i might run out of injector and turbo when raising the boostlevel to around 18, maybe 20psi
the truck is street driven, so i´m mainly looking for fast spool, good response and lower end tourque - i was thinking a turbo in the 67 range or maybe a ballbearing turbo and 75# injectors should do the trick but i´m open for your suggestions - i will also contact nolan for one of his custom tunes.
i also have some general questions for you guys:
- will i need alky injection to savely run this boost levels in a daily driver?
- do the 75# injectors sacrifice drivebility, idle etc.?
- what kind of hp can i expect with a save tune and 20psi boost?
- any other upgrades reconmended?
- will my single walpro support this built or will i need a upgraded pump?
thanks!
thanks!
