CA Smog Test vs SyTy
2kwik4u
Resident slow guy
Re: CA Smog Test vs SyTy
There, I touched it up a little for you Mike.
Thank you sir......same premis, more specifics......
You're welcome to use my address to register any of those cars/trucks. ZERO emissions testing or inspections here in KY. I often wonder about some of the cars I see on the road being safe to be there, then I realize it's a risk I'm OK dealing with to insure I'm no longer bothered with it myself.
I'm still curious if a custom chip would set of the CA smog police. Simply run the truck with the brown wire off (since it seems to pass every time that way), and have the flag in the chip disabled for setting the CEL under no ESC communication. Make sense?
syclone809
Health & Safety code 44081
https://www.dmv.ca.gov/pubs/vctop/appndxa/hlthsaf/hs44081.htm
I spoke with a friend @ the CHP, she says they don't organize this, or enforce any violations, they are purely there for traffic control and car selection. The tests are conducted by B.A.R.(Bureau of Automotive Repair) 916-403-0315, I called Sacramento and that's where I was given the H&S code that constitutes this operation, the person I spoke with also said the test is VOLUNTARY even if selected by an officer, and it's to collect real time data of exhaust gases to see the effectiveness of the current smog program.
green73
Not looking forward to this aspect of military retirement. I'll probably end up staying here in Kern County, working on Edwards. I have all but 1 of my vehicles registered in my home of record. I am sure Commifornia will force me to register them all here, should the most likely post mil retirement job happen. I'll drag my feet in getting it done too. It isn't that I don't want to pollute the environment, but I just don't get the stringent enforcement. Really just how many 1974-OBD1 vehicles do you see driving around in this state compared to OBD2? Is it really worth the cost of this legislation, enforcement, and "voluntary" BAR roadside "test" (flagging your car) programs? Oh wait Commifornia, so, yes. Guess I need to friend a smog guy and get an idea where I currently am with the pertinent test points. The only mods are the Hood Stock+ ECM, Walbro, and Adjustable Regulator. All the other stuff I've done shouldn't change any emissions test points.
Damian
She is full if shit, I have friends that have had their car impounded for being "illegally modified".
Z SKI
Yes they will chase you down. They have a smog dyno on a trailer. Any car that does not pass smog or visual will get a ticket and or towed away. Who says nobody walks in LA. I have ran into several of them. Lucky for me. The officers that randomly pick what cars they want on the dyno let me pass. I had one officer say nice Syclone.
I call bull on this.. I talked to a CHP friend of mine today and he has worked these details many, many times in the South Bay. He stated that you CAN refuse to take the test and they CANT force you to test your vehicle.
Now if you see a road-side smog test station and make an illegal U-turn you will be stopped for the moving violation.. If you are waiting in line and an equipment/ vehicle code violation is observed you will be getting a ticket or a talking to... Then it basically turns into a hasty traffic stop... During these hasty traffic stops if you are found to be driving with no drivers license or be over six months expired on your vehicle registration... Then your vehicle will be towed...
Hope this helps clear it up a little...
My CHP buddy said that the one that takes a picture of your plate and sends you a notice is a different breed and even when they come in contact with heavily modified vehicles (I.E. street racing) they don't tow just for modified vehicles but they may make you go to the SMOG referee :2cents:
XMOJOX
I had a California Smog license for many years. I did a lot of smog inspection and testing when I worked at a dealership decades ago. I understand the interactions of what affects emissions. The problem is that without an Exhaust Gas Analyzer, you're just guessing whether the 'fixes' you've just done are effective or not. I've wanted to have my own machine for several years now. So I can pre-test, and if needed, repair my own cars prior to inspection. Especially now that it is such a huge investment in time for the inspection.
Every now and then I troll CL looking for used machines. I haven't found anything. They are never listed when I look. I found this machine last night. I'm thinking of buying it. Not only for my own use, but to also 'assist' other SyTy peeps with pre-inspection / repairs. Would any of you South Bay peeps be interested in this "service", and would it be worth money to you? Probably in the $200-ish range for an afternoon of dicking around figuring out a solution, but at least with the confidence that you should pass tailpipe emissions when you leave.
As I state in my post above, I have solutions for my cars so I don't care any more. I'd spend the $1,400 for this if I think I can earn it back in a couple of years or so helping you guys.
Dave, I would be your first customer. I've recently failed smog testing twice. Jason and I have tried to play with the timing but to no avail. These days, I have more money than time, so where does the line start?
Damian
It's all about tax money. What brings in more tax/registration money, a 93 Typhoon or a 2014 Chevy SUV? The 2014 of course. So they put the squeeze on older vehicles so you have no choice but to trade it in for a newer vehicle.
ajt86
They do mobile inspections in Nj too... if you try and turn around the cops come chasing. I have no cats on my ctsv and i sweat bullets driving through the check points
Ive usualy found as an emissions repair tech, if you have high HC... your fuel trims are normal, to do an ignition tune up and verify theres no vacume leaks, and if its still high ive always replaced the cat and it always fixes it. Cats become less efficient as the years go by and the miles rack up
taking the bulb out wont work... no bulb check is an automatic fail.
AppleTY
What is the status of your Catalytic Converter?
My truck hadn't ran in 12 years, found that the Cat was clogged up, put a new CA legal Magnaflow on and I passed with ridiculous numbers. All stock, 135000 (hard) miles, timing at 0.
syclone809
Do you know her? Personally? Is she a liar? Do you work for the CHP? Would it have made a difference if I said I spoke with a male friend like ZSKI did, assuming his friend is a male? Is his friend at the CHP full of shit also?
I think your full of shit! There is more to the story of why your friends got their car impounded, 3 sides to every story. Maybe it's the pompous arrogant prick attitude you DSM ricers carry around with you, thinking everyone is full of shit when you're the ignorant 1 who hasn't educated yourself on the law. I'm guessing it had something to do with the way they handled the situation more than the "illegal mods" and it doesn't make for a good case when you have a ridiculous 4in. muffler sticking out the back. As I said it's VOLUNTARY, if you'd like I can give you the CHP # so you can hear it DIRECTLY from the horses mouth, and then tell them they're full of shit because your friend said so. I've PERSONALLY been in numerous situations, street racing raids, etc. where "illegally modified" cars HAVEN'T been impounded, and some have, it's how you handle the situation.
Then again, your breaking the law so what do you expect? Did you read the fine print when applying for a CDL or registering a vehicle? About gross polluters and modifying smog device's? I posted a link, did you even read it and educate yourself? or just shoot off at the mouth?
Next time don't let that snake tongue slip out of your mouth so quickly. The person you claim is " Full of Shit" is my fiancé, I didn't feel the need to disclose that, so I referred to her as a friend :tup:
Back on topic, as BRWNDRVR05 said, it pay$ to know the right people, Jaystcb if you need that service, send me a pm, even though it's not fixing the issue at hand, it will keep your registration current. Although after several times it's more practical financially to go Dave's route, since our inspections are Biennial and the amount spent will surpass what a test machine would cost.
jaystcb
Sy 0902, 92Ty 0909
"Catalytic Converter" That is the next step with the Ty.
I like your stock Idle at 729 ???? Humm. I had to Tunerpro to get my idle down enough to pass. We will see what comes up this weekend.
I will let you know.
Thank You guys for your input.
Z SKI
You know me Dave!!! I would be interested..
AppleTY
I would suggest testing if the Cat has gone bad.
Take the truck out for a drive, lift it up and measure the inlet and outlet temp of the Cat.
If the Cat outlet temp is about 100deg hotter than the inlet, then the Cat is working correctly.
If the Cat outlet is cooler than the inlet then the Cat is bad and should be replaced.
Hope you have an IR thermometer. Don't use your hands!
Audio Man
For the record, I had my cat changed when my truck would not pass emmisions in GA and that was the one thing that did the trick. Passed easily after that.
I had changed everything, cap, rotor, plugs wires, timing, sea foamed it to clean the top end out, fresh oil change, nothing did anything to help it pass, stayed about the same. The last thing I did was the cat and it changed everything.
Same with my 94 ful sized Blazer. Did EGR, plugs wires, cap, rotor, oil change, Sea Foam, the whole 9 yards..no difference in passing till I did the cat.
I just wondered how much difference it would have made if I had left everything else alone and just done the cat.
green73
I get that to an extent. Problem is is screws those of us that have older vehicles as a hobby, not single vehicle daily drivers. 99% of us want and keep our stuff running good and clean. Somehow this is always just outside of acceptable environmental allowances :rotf:.
Damian
What they are allowed to do and what they do is two completely different things. If participating in these mobile smog checks is voluntary, then why do they chase after you if you turn around? Why are they doing these random checks anyways if all the information they need is available from the info the smog shops submit to DMV? Why do they target imports and not domestics? My buddy had an Eclipse like mine (NOT a DSM) and a modified Camaro that he had to take through those check points and the Camaro never got picked to participate in the smog check. His Camaro had gauges and crap all over the place like his Eclipse but that's fine, not fine in his Eclipse. Why is that? So for any CHP officer to tell me that's it's up to the driver if they want to do it or not is BS.
jaystcb
Sy 0902, 92Ty 0909
Out of all the crap in my SyTy toolbox. I have now found somthing I dont have. Today, after work I am going to buy one of those laser temp guns to check the CAT. Thanks.
Damian
If you were closer I'd let you borrow mine. Harbor Freight has them though.
