Re: cam question
Well... First I'm no cam guru so this is mere token observation. That being said I'm running a "custom" Comp cam in my motor and I'd have to say I'm very pleased. Last race of the season I ran 11.95 @ 116 with a 1.797 60'. All on just under 20# of boost. Remember I have nothing to compare these numbers with, IE other trucks, similar build etc but I think these numbers are pretty good.
You'll need to be sure to check that your springs don't bind at these lift numbers. Overlap might be on the high side for a turbo motor and IMHO here's the big problem. You have 60* of overlap. That's way to much. As I understand cams for turbo motors have anywhere from 0 to single digit overlap numbers. Maybe even a negative number. My cam has +5*.
I'd definitely research this further.
If you want the info on my cam LMK I'm sure Comp can make it for you. I have all the part numbers ect. If necessary I can even put you in touch with the cam designer/guru at Comp that recommended this cam. His recommendations might be different for your exact build. He did say that he had a cam he would rather use (for my build) but it required 1.6 rockers and I already had 1.5's.
EDIT: Regardless of your decision don't just slap the thing in the motor. Degree the cam, either by you assuming you know how or pay someone. Well worth the $$ in my opinion.
HTH
