Throws
Background:
I had an issue a couple of weeks ago where my PLX M300 stopped providing a real reading, instead opting for for alternating between 14.70 and 14.69. Same ad you get if the sensor isn't connected. I only found this after noticing one day that the Ty was stumbling on idle and generally sucking. So I swapped a new narrowband in, and all was good. So, I looked at the harness for the PLX and found 2 broken wires. I replaced the harness connector ends up by the PLX. Tinned, crimped and soldered in 12 new connectors. Fast forward to:
Today:
Decided to get the PLX back in this weekend, and found that my work (seemed) to pay off. Swapped in the WBO2. Looked good, was changing values... but then I noticed it was stumbling at idle again. Idle would go to 500rpm and the PLX was showing 19~ish and then really stumbling bad. Read that it was reccomended to drive over 30mph to reset some values.... no changes.
SO.... Is it possible that the PLX box has given up and it's time to get a new DM6?
-P
Today:
-P
