Hu Ryde
On 2002-03-24 12:03, Stanley Spadowski wrote:
I also know of some people who have used the newer cast aluminum pans on Syty motor buildups. I'm curious if the Eagle rods clear these pans... putting a fitting for a turbo oil return would be cake on these as well, and you could use a *common* size, rather than the goofy size the stocker has, so a 12AN hose line conversion could be done.
Is there any advantage in using a Cast pan? Hold more oil, or cools better? Can it be changed with motor in easily? I would look but trucks not here.
