Check Engine Light on & Smells Like eggs
B
Blkty819
Guest
My Truck runs strong but I changed the CAT and it smells like its running real rich (smells like eggs)and is blowing some oily condensation in my driveway out of the exhaust. It is still has power but hesitates breifly when I step on it. I noticed the air intake hose into the turbo has some oil in it and both Pcv valves have oil in the line. Anyone know about that canister underneath the oil filter that I think has something to do with exhaust. Also check engine light comes on and off periodically.
KB coolair kit
Billet adj fp reg
KBstreetmaster chip &40lb inj
Thanks for your help!
'92 TY 819
93ty475
how long have you owned the truck? might want to consider a stock chip and injectors to start as well as a scantool like datamaster or turbolink...my ty came with 40lb injectors and a kb chip...it ran terrible and the ecm wasnt retarding timing when it knocked...it ran 100 times better when i put a set of stock injectors in and replaced the stock chip...good luck
edit: might want to have a compression check done on your engine...the condensation, if excessive may actually be a cracked head or blown headgasket...those kb chips are potentially dangerous from what i've read...
InvisiBill
Have you changed the PCV valves?
The charcoal canister collects gasoline vapors. I think it passes them to the intake to be burned. It really doesn't have anything to do with the exhaust.
Pull the trouble codes and see why the Check Engine light is coming on. The code(s) will be stored even if the light doesn't stay on. http://www.sportmachines.com/maintenance/aldl.php
InvisiBill
From a PM...
Blkty819 said:
I changed both PCV valves. when I checked the codes with a paperclip I am receiving a code 45. Would the KB chip I have effect the code I receive? Is this code accurate? Because a code 45 states check charcoal canister & running too rich & I can't figure out the egg like smell it is putting out.
45 is the rich exhaust code. "Check the evaporative charcoal canister and its components for the presence of fuel. Replace the oxygen sensor." Did you do those? Have you looked at the spark plugs to see if they indicate running rich?
If the spark plugs and charcoal canister look fine, but it's still reading rich, the O2 sensor might just be screwed up (i.e. it's running fine and the sensor is wrong). A scantool showing the O2 mV would help diagnose a bad O2 sensor.
If the plugs indicate it's running rich too, then the sensor is right and there's something wrong. If the charcoal canister is ok, then you have to look at other stuff. The chip might just be a crappy calibration. You might have leaking injectors. You'll have to test to find out where the extra fuel is coming from.
http://www.syty.org/old/promguide.html
Also note that there are two 40lb injector chips by KB. The street version has NO KNOCK RETARD. Even if your pistons are smacking against your spark plugs, the ECM won't retard timing to prevent damage. Yes, you will go a little faster because the ECM isn't pulling back, but you're also damaging your engine in the process. There are many stock injector trucks down into the 11s. If you don't have any more mods than what you listed in the first post, you don't need bigger injectors. Switch back to the stock injectors and chip.
turbodog
Check fuel pressure as part of your diagnosis. I had a FPR fail 'wide open' and it caused a slight rich condition.
B
Blkty819
Guest
Thanks All of you for your time I am working on it. Will post outcome
