Chip & Burn Bin to TP?
jaystcb
Sy 0902, 92Ty 0909
The Story,
This weekend a friend brought over his car so we could burn a new chip from a bin file that he had saved on his laptop.
The car. 1986, Stroked 383 Supercharged Vette.
Question #1 What could cause the check engine light to turn on with no code?
I was able to upload his bin and burn it to a chip. But when we installed it into his car, The check engine light came on and stayed on. No code? We put his other chip back in and No check engine light.
We tried 2 different chips.
Question #2 How come TP will not recognize the bin files saved from Chip&Burn?
We also uploaded and saved bins from several of his previous chips that he had the tuner make. I uploaded his bins using Moates "chip&burn" and saved them as a bin file. But Tuner Pro RT would not open the bins that I saved using Chip&Burn. TP would only open the bins that I downloaded from his laptop to mine.
Also I tried doing the same thing with my Sy and no luck. I think it is a formating problem. But I cant find the correct location on my laptop to change the file.
I am using XP
Any Help.
Re: Chip & Burn Bin to TP?
Assuming its still using the 165 ECM, you probably need to write the chip to 4000 offset.
This is because the bin is 128k but the EPROM you are probably using is 256k. Stock SyTy $58 mask bins are also 128k but code59 are 256k.
jaystcb
Sy 0902, 92Ty 0909
I burned bins to a 27SF512 and a 27C256 chip. Both caused the check enging light to turn on.
I will try to set it to a 4000 offset.
Thank You
I was using this chart.
http://static.moates.net/manuals/FlashAndBurn.pdf
EDIT
the second EPROM was a
27C128
and the ECU/ECM is a 1227165.
