background:
ok where do i start.... im trying my best to chip tune my syclone. i have started to notice that when i install a chip it runs kinda rough, and then smooths out some, and ultimately gets better on the second day ive been driving it. i didnt originally realize this, and every time i try to change a few things in the fueling or timing i end up reverting back to the original program thinking that i have mada a bad adjustment. actually i dont think ive been making poor adjustments, i think im just confusing myself bacause when i burn a new chip it "seems" to run worse than the one ive been running for a few days. well duh! the truck is learning something in the fargin program and causing the drivability to get better. anyway, now that ive realized this, im trying to figure out what exactly my truck is modifying, so i can disable it so i can start making my own corrections. i automatically "assumed" the .bin file i started with was running in open loop, but now im not so sure..........
in the P4 document it says
"if *KO2ATIME* is set to zero, closed loop operation will not occur.
i also saw this......
"the coolant temperature criterion for closed loop operation is met when the coolant temperature is greater than *KCLTC*
which is the correct way to create open loop chips? does either option have ill side affects that would make one better than the other?
my *KO2ATIME* is currently set at 10
and my *KCLTC* is currently set at 50deg C (122deg F)
it looks to me like im using a closed program.
should i assume im operating in closed loop, or are there more entries i need to check before assuming that?
also, are there any other things that could be causing what im feeling? i immediately thought of the closed loop/open loop learning routine, but i didnt know if there was something else that could be slow learning. IAC mabe?
please dont take these questions like im a tard, im learning as fast as i can, from reading, and from trial and error.
thanks for helpin the nOOb.
also if anyone would like to look at a datamaster file there are two on my webpage. "mccoycam#4" and "mccoycam#5"
e
e
