Quickstop [UK]
Combating adversyty.
OK,
I have got a code 13 at the same time as CODE 45. How?
The ouptut from my LM-1 is 60mV (too low I think) and when I run DataMaster, it says the O2 mV to be around 450mV.
I know that the ECM is receiving the input from the O2 sensor ( Ithink I know) as the idel was rrally bad when I accidentally grounded the narrowband analogue output.
If I remove the O2 sensor from the ECM completely, it still registers in DM as around 450mV.
The LM 1 responds instantly to the throttle and changes in AFR, so that is fine (idles better around 14.7, idle gets bad if it leans off, if you apply throttle and then cut it sharply it goes very lean briefly all of which you would expect).
So the ECM seems to have a mind of its own perhaps?
Anyone got any ideas?
thanks,
Mark
thanks,
Mark
