CODE 43... after new knock sensor and esc module
fivetodrive
CRISPY
So I am finally working on crispy but it's not going well. First had a stuck injector. Replaced those with a freshly cleaned and flow matched set. That cleared the code 45...
Still struggling with the 43 though... Could it be voltage related? I onlyseem to get 13.5 out of my polished alternator...
Any ideas?
ajt86
Re: CODE 43... after new knock sensor and esc module
I had a code 43 in my typhoon... the timing connector in the interior was corroded from a leaky heater core... cut the connector and crimped the wire and it never came back
wildphil
I Love My Ty's
Also make sure the knock sensor is the correct one for our trucks. I parts store that I bought one from before shows the incorrect part number for our trucks. Had to do a little searching to get the right one.
Logan
I will second this. I got one from O'Reilly Auto because they have Borg Warner parts but it turned out not to work. I had to get a GM one and it fixed it.
fivetodrive
CRISPY
Paul sent me a known good knock sensor. I also verified it works in datamaster. I will swap out the ecm and chip later today... It comes on 5 seconds after I start the truck...
fivetodrive
CRISPY
Well I'll be a monkeys uncle... Replaced the ecm and chip... No more code 43... HERE'S TO STOCKPILING PARTS!!!
Was this the tan wire?
fivetodrive
CRISPY
Update... No this was not the case. Still have the 43. I have another memcal at my desk at work. Will try it tonight.
ajt86
yes tan with a black tracer at the passenger side footwell
fivetodrive
CRISPY
Not the memcal. All signs looking towards a broken knock sensor wire. Will test for continuity tonight...
fivetodrive
CRISPY
Ran a new wire directly to the knock sensorwith junkyard pigtails... Still there so I broke down and bought a new knock sensor from GM today. Fixed the code 43... Ugh... But good to be gone... Now I have a code 45... Too rich at idle...
fivetodrive
CRISPY
Thanks Dave! I have plenty of wiring issues next! Lack of grounds is next on my list!
