When mine went bad it still detected knock but it was going haywire and not recieving the right voltage. If you want to verify it is detecting knock bang on the intercooler or intake with a screwdriver handle while watching a scan tool. it will say whether it is detecting knock. It is really easy to replace the sensor.
first get the right one! there are 2 of em availiable for our motors one for the standard 4.3 and one for the z vinned motors. I know this because the parts guy looked it up the ran my whole vin number and it came up as a different part number that he had to order. I went home last night and got my old one and my new box but the part numbers isnt on the box but I can give you the number off the sensor.
steps to replacing the sensor.
1. the sensor is on the block behind and below the distibutor
2. take the coil off it makes it easier.
3. take the bolts off the wiper motor so you can move it around.
4. Reach down in there and pop off the connector on top of the sensor, I had to use a screw driver.
5. get the right combo of swivels and extensions. I had a ratchet 2 swivels and a impact socket on a 8 inch extension that seemed to work the best.
after you get it out some people put teflon tape or silicone on the new one to insulate it. put it back in and I beleive torque on it is like 8 pounds or something. before you put everything in make sure you test out the sensor.
hope this helps
