Coolant leak, drips from starter
Sy Guy 0024
I've got a coolant leak in the Ty, small drops are forming on the starter and starter bolts. I can smell coolant after engine is heated up, but never any drops or puddles on ground. No white smoke from tailpipe. Coolant level is dropping though.
Head gasket above starter looks a little wet, but the valve cover appears to be seeping and running down near head gasket area so I can't tell for sure. Did a pressure check, pressure holds steady.
It's not coming from the heater core.
Has anyone had this happen before? I just can't see where the leak is coming from...
91blazins10
Re: Coolant leak, drips from starter
Maybe check the hose that runs to the heatercore itself it runs right around that area, also you might wanna check you intercooler (you said your coolant level is dropping so its prob not that) but worth checking anyway. I know that my intercooler leaks a few drips from the back hoses every now and then.
Sy Guy 0024
Nope, I'm air-to-air with a PT-54, so no coolant to IC or turbo. Thanks anyway though.
Sy Guy 0024
Sure, I'll wipe em down and check for seeping. It's difficult to see, as the block is oily and there is no concentrated wet spot.
Try Me
intake gaskets or intake bolts could leak coolant. i had water coming out of the front intake bolt on the passenger side and it ran back the motor :2cents:
live1053rulz
Nor Cal SyTy
That'd be my bet. Might be hard to get to the front ones, might be hard to get to most of them actually.
