Correct TPS values. Did Search.
Hello everyone. I would like to know the correct TPS voltage values ( Idle to WOT) for my 1992 gmc typhoon.
I recently change out the TPS that came on the ty with a new GM unit. Upon removal I noticed that the previous owner opened up slots for adjustablity I assume. The new from Dealer unit P/N's GM# 17112368, AC DELCO# 213-908 has no slots just upper and lower fixed holes, There does appear to be an outline of where a slot could have been cut from the factory.
My current values ( new non adjustable sensor) using Datamaster are as follow:
( Idle = 0.80V/0.0%), (WOT = 3.45V/83.9%)
The older sensor with slots read 0.5v at idle old datamaster file. no wot recorded at that time.
The Ty seems to have sluggish performance with this new sensor as opposed the slotted version. Just trying to get back to where I started.
Thanks in advance for your responses
jaystcb
Sy 0902, 92Ty 0909
Re: Correct TPS values. Did Search.
You can doubble check your reading by using a multimeter.
I used a multimeter set at DCV-20
i used a small paperclip to backprobe the B wire of the TPS.
Attach the red wire of the multimeter to the paperclip and the black wire of the multimeter to a good ground.
Then turn the ignition to the ACC position ( two clicks forward from the off position. do not start the engine).
Then check the reading on the multimeter.
MY SY had the following readings.
B wire (blue) output wire has .64V @ idle position , 4.54V @ WOT position
I hope this helps
Thanks for the info guys. Does your Throttle position sensor have slots for adjusting from the factory or did you cut slots to adjust for those readings?
I am curios if the replacement I have is correct as it does not have slots to adjust?
The tps isn't adjustable because the ECM self zero's the sensor. I would be a little concern if it doesn't read 100% tps at wot though.
NJ93TY
Your not getting close to 5V at WOT check to see if the throttle plates are opening all the way up, cable could be stretched or gas pedal could be bent or check to make sure your floor mat isn't stuck behind the pedal.
