crapping out after freeway drive
Big Mike
Re: crapping out after freeway drive
Fuel pump time, don't forget to change your filter too. So you going to drop the tank or pull the bed off?
Throws
Agreed... if you haven't yet (or aren't sure how "genuine" that Walbro is), replace that pump.
-P
blue83z
at least you broke down at the liquor store......just kidding man, hope you get it fixed.
jaystcb
Sy 0902, 92Ty 0909
My 1 hour fuel pump change turned into a 4 hour, busted knuckle, pain in the ass thanks to some rusty bed bolts. But I got them off, 1/16th turn at a time.
I replaced it using a new Walbro 255 and kit.
All done.
teamvortec
My ty had a lil miss to it and would cut off some times. And sometimes it was hard to start. Dropped the tank and installed a Bosch and problems went away. Bad part is the pump doesnt have 500 miles but it is about 14 months old. Guess its time to buy another one.
jaystcb
Sy 0902, 92Ty 0909
I took it for a drive today and it died after about 40 minutes. Then I took it on another 40 minute drive home. It died several times. After I finally pulled in the driveway I hooked up a FP gauge. A test light to the FP (big red in video) and a video camera. This is what I got now. I have Fuel pressure. I have power to the fuel pump. But truck still dies.
Now I'm thinking faulty oil pressure sensor, clogged cat, bad ignition module, faulty ECU. why would it die when it gets hot ???? any ideas?
http://youtu.be/0O-Lr-BUGl4
Racer X
I have been watching this post with baited breath because my Ty is doing the EXACT same thing. I have tried a new coil, ignition module, wires, fuel pump, wires, rerouted IC hoses---and nothing has worked. Good luck.
If I find the gremlins I will let you know....arrrgggghhh!!!:rant:
I would sell it if it wasn't so much fun when it's running.
Justoyz1
Typhoon #849
I see that you changed the fuel pump and the strainer, but did you change the fuel filter? It's a in line type.... Your issues seem to be that of a clogged fuel filter, which put a strain on your fuel pump and aided in it's demise. When they get clogged or stopped up, it will allow you to travel for a short while; when too much load is there it can't handle it gets clogged worser.
-Change the fuel filiter
Quickstop [UK]
Combating adversyty.
A: Is the oil pressure switch working correctly. To test, have truck running. Un-plug fuel pump relay. Engine keeps running = oil pressure switch OK. Engine dies = oil pressure switch bad.
B: If oil pressure switch is good, it's probably the fuel pump, or wiring to the fuel pump. Particularly the in-tank connector at the top of the tank.
C: If oil pressure switch is bad, then the fuel pump relay is probably also bad.
But the way I read this, the only thing you touch is the fuel pump relay. While I have no idea why cranking with the pump disabled causes it to re-start, it's still associated with the pump, IMO.
The fuel pump in my Corvette would make it stall at idle, or when I shoved the clutch in to shift. I'd let the clutch out, and it would fire right back up. I replaced the pump, and it's been fine for 7 years since.
I would be suspicious of the pump, or wiring for the pump.
For posterity.
