atomicmecha
I hate rust
So I got my typhoon back to 'running' condition today. running being relative. Its all over the place on the air/fuel. It sticks at 14.7 for a bit then drops down to 15-16ish and comes back. Something is going on. sticky injectors? bad sensor? lets find out!
Well... dug out my old laptop that had datamaster on it and WAS working before and its hosed. I might be able to repair windows but I really hate doing that when I've got a ghost image already and can reflash the computer in about 20 minutes. So I figured I'd just put it on my newest laptop and go from there. Well... its installed. Installed the drivers for my OBD1 cable. Com4 shows up now under windows settings. Etc. Looks like everything is fine. Its not.
Normally computers are my strong spot (go figure since thats what I do). But this is leaving me scratching my head atm and I feel like its because I over looked something small and simple. So I need a fresh mind atm to help me.
I got the ADL test program as well. IT DOES see the com port 4 and I can run the tests. But they all fail. Data rate shows good at the end tho. I even did the extended test to run all the various speeds.
Atm the port is set to the windows defaults and a 9600 baud rate. I dont remember having to change that in windows last time. I do remember having to tweak the settings within data master but that was AFTER it saw the com port and was connected.
Datamaster isn't even seeing the port atm.
I also removed and re-installed it thinking maybe the cable needs to have been installed prior to the program. Nope.
So help me take a step back and see what I'm missing? I had to take a break because I had forgot to charge my laptop last night anyway and now its dead. Going to try again tomorrow on a fresh charge. :tup:
