datamaster 3.4.1 needed
Norm
Re: datamaster 3.4.1 needed
I have a 3.3.0 version. Is that close enough? All the cables also.
Rexxenexx
Here's a couple listed DELETED (checked out the 351 and it looked sketchy so I didn't install it-gonna try benders links)
3_5_0 Beta is the one that I have that is working with "magic". I'm gonna try 3_5_1 from the link above and see if it has "magic". "Magic" is for 3_4_1 and I don't think it'll work for the 4's so 3_5_1 is probably our best bet. Gotta support your software otherwise magicians will. ;)
bender
Here's a couple listed http://webcache.googleusercontent.c...er/+setup-TT_351.exe&cd=2&hl=en&ct=clnk&gl=us
Im running 330 because I like the knock counts being real. It also works with what I believe you call magic. Also worked after copying the magic from win xp to win 7 which somehow made the magic better, i dont even have to click on it anymore it just works. It works w/ my usb aldl, real knock counts and works in win 7. What would be the advantage of the later versions.
Rexxenexx
Version 3.4.1
* Added the ability to monitor-only data without opening a file.
* Revised 2- and 3-bar MAP sensor calibrations for the Syclone / Typhoon turbo (DataMaster TT).
* Enabled oil temperature display for all 94-95 LT1 applications.
* Fixed crash on minimize of Dyno and Spark Retard form.
* Increased max file playback length to 32,000 records.
I dunno the difference between the rest but it should be bug fixes right?
EDIT:
--Version 3.5.1 19-Oct-2005
Fix speed-distance form ‘hang’
--Version 3.5.0 06-Oct-2005
Added support for USB serial Interfaces
Improved form load / unload performance
Updated install paths
Manual is now a separate install
--Version 3.4.17 21-June-2003
Last 16-bit installer release
The one that came with my old datacable was called 3.5.0Beta2 installs as 3.4.1 and the About says 2001 as the date. Either they didn't bother to update the date for the beta or the one I'm using is actually 3.4.1. Anyway I still have to order a USB cable to make sure it totally works. 3.5.1 and 3.4.17 can't use magic. They're different file sizes.
EDIT:
Byte for Byte 3.4.1 and 3.5.0 Beta2 that I have are the same. So the one I'm using is 3.4.1.
sytyguy
Moderated User
In our first PMs, I sent you the link man. Check your inbox, I'll send it to you again.
