datamaster log
cdprayor
Re: datamaster log
Rpm stage 1 turbo, 3" downpipe, 58mm throttle body, rpm a2a intercooler, rpm cold air intake, snow meth kit, 3200 stall, egr delete, msd coil and 6al.
WyoSyclone
Re: datamaster log
Do you still have the Cat in place? Stock injectors?
Log looks like your running out of fuel.... injectors are pegging full open, drawing a lot of current, and causing your supply voltage to drop down to 11.7. You should look at doing the mod to add extra current capability to the ECM.
The intake temps get a bit high for having the A2A on it... what was the ambient air temp during this log.
Is it the stock factory chip in the ECM, or have you added a chip? You definitely need to go 3-bar and wideband O2.
I've also got the rpm Stage1 on my Sy with a modded RPM fresh air.... would be interested to see you get into Code59 with the 3bar map and wideband.... then we could optimize the tune for your mods.
cdprayor
Re: datamaster log
No cat and stock injectors. It's suppose to have a 340 pump installed. The chip is suppose to be from rpm for the stage 1 turbo but I cannot confirm that. I know it does have a chip along with the factory chip. All I seen on the chip when I removed the computer was moates. I believe it does have a wideband o2. The is an autometer gauge for it on my pillar and seems to work. I couldn't tell you what kind of wideband though. I will have to check and see what ambient temps were when I get home. Fuel pressure was set at 40 psi with vacuum hose on. Thanks for all your help.
cdprayor
Re: datamaster log
Also it has a cold idle issue. I have replaced plugs, cap, rotor and wires also iac and nothing has helped. Also replaced a few vacuum lines but I am going to order a set from sportmachines
WyoSyclone
Re: datamaster log
If it has Moates on it, it may be running Code59.....I should have checked that. I need to run errands for a few hours but can do some more checks when I get back
WyoSyclone
Re: datamaster log
Nope, not running Code59. It's running closed loop. I'd bump the fuel pressure up to 44 or 46 psi to help the stock injectors keep up with the mods... you'll want to be looking at injectors, then Code59 so you can dial in the tune.
cdprayor
Re: datamaster log
Just pulled my map off. I can't see any part numbers on it other than 1000h27. Did a google search but it didn't bring anything up. Looks like it may be a autometer 2249. http://m.summitracing.com/parts/atm-2249. I will bump my fuel pressure up and I am going to log a 0-70 run in a few minutes. What injectors would you recommend? Thanks for all your help WyoSyclone.
WyoSyclone
Re: datamaster log
Here is my 0-70 run today after I adjusted the fuel pressure to 45psi. I noticed my tps% was only getting about 75%. I have since fixed that issue. http://www.mediafire.com/download/la1khj55ksxxk1i/0-70_run1.uni
That actually helped a LOT..... it took your injector DC down by 15%, which means they're no longer running saturated at WOT, and your ECM voltage has come back up as a result.
It only shows you running about 9 lbs of boost right now, but that's a good things with the tune not being optimized.
You're getting little KR, and the increased FP took care of the lean O2 DTC's you were getting.
Looks like it's safe to drive 'as-is'. If you want more performance (higher boost), you'll need to upgrade injectors. The 60/63lb Siemens seem to be the best way to go... very linear and they don't require ECM mods.
Hope this helps.
cdprayor
Re: datamaster log
Thank you for all your help WyoSyclone. Since I adjusted the fuel pressure, fixed the tps issue and used some octane boost with my 91 octane gasoline it is actually running quite well. 91 is the highest grade we have around here. Idle has smoothed out, seems to run cleaner and doesn't try to die with a/c on. I cannot complain at all. Thanks again
